Sparkler icon
Performance & Maintenance Utility
Keep your apps' auto-update frameworks clean, configured, and under control.
Download Free
Sparkler screenshot Sparkler screenshot
Auto-updates, without the XML
Sparkler is a standalone tool (not affiliated with the Sparkle project itself) that generates the appcast.xml file developers need to ship automatic updates through the Sparkle framework.
Drop in your release's ZIP file, fill in the release notes and download URL, and Sparkler signs the update and writes the appcast for you — no more hand-editing XML.
Sparkle Framework
Independent, not affiliated with Sparkle
EdDSA Signing
Built-in key generation
Auto-Populated
Appcast fields filled for you
Zero XML
No hand-editing appcast.xml
Release updates, without the busywork
Sparkler handles signing and appcast generation so you can ship updates faster.
Appcast Generation
Builds the appcast.xml file Sparkle-powered apps need for auto-updates.
Drag-and-Drop Signing
Drop in your release ZIP and Sparkler signs it automatically.
EdDSA Key Management
Generate and detect your signing key without touching Terminal.
Auto-Populated Fields
Appcast fields fill in automatically the moment you select a file.
Built-in Verification
Verify your selected file before generating the appcast.
One-Step Publishing
Upload the finished ZIP and appcast.xml straight to your release URL.
How to use Sparkler
  1. Download the Sparkle framework's command-line tools from its GitHub releases and copy them to /usr/local/bin so Sparkler can find them.
  2. Compress your finished app into a ZIP using macOS's built-in Archive Utility.
  3. Drag the ZIP into Sparkler (or use Select File) — the appcast fields populate automatically.
  4. Confirm your EdDSA signing key is detected, clicking Generate Keys first if you haven't signed a release before.
  5. Fill in the release notes and download URL, click Verify Selected File, then Generate Appcast.
  6. Upload both the ZIP and the generated appcast.xml to the URL you provided.
Big Sur 11.0 or later
CLI Tools
sign_update, generate_appcast, generate_key
Location
Installed to /usr/local/bin
Auto-updates,
without the XML.
Sign releases and generate appcast files for the Sparkle framework in minutes.
What is Sparkler used for?
Sparkler helps developers easily create, manage, and sign appcast.xml files for applications that use the Sparkle auto-update framework.
Do I need to be a developer to use Sparkler?
Yes, Sparkler is a developer tool meant for those who are distributing macOS apps outside the App Store.
