Gatekeeper Toggler
Enable or disable macOS Gatekeeper security checks in one click.
spctl commands for you.
Security checks, one switch
Gatekeeper Toggler flips macOS's Gatekeeper security checks on or off from a single switch, useful when testing unsigned builds or running tools that Apple hasn't notarized — no more retyping spctl flags from memory.
Gatekeeper checks that apps downloaded outside the Mac App Store carry a valid Apple Developer ID signature before letting them run. If an app is unsigned, tampered with, or from an unverified developer, Gatekeeper blocks it — which is usually the right call, but occasionally gets in the way of a tool you trust. (Apple has more detail in their official Gatekeeper support article.)
A green padlock means Gatekeeper is on; we strongly recommend switching it back on as soon as you've finished the task that required it disabled.
Security, on your terms
Gatekeeper Toggler makes flipping macOS security checks fast, visible, and safe.
spctl flags entirely.Guide
How to use Gatekeeper Toggler
- Open Gatekeeper Toggler — a green padlock means Gatekeeper is currently enabled.
- Click the slider to disable Gatekeeper, then enter your administrator password to confirm (click Cancel to back out without changing anything).
- Open or install the app that Gatekeeper was blocking; when the security prompt appears, click Open.
- Once you're done, return to Gatekeeper Toggler and switch it back on to restore full protection.
Security checks,
one click away.
Enable or disable Gatekeeper instantly — no spctl commands required.
