ISO Image Creator icon
Boot & Installation Utility
ISO Image Creator
Convert DMGs and folders into bootable ISO images effortlessly.
Download Free
ISO Image Creator screenshot ISO Image Creator screenshot
News: ISO Image Creator's functionality is now built into Bootabler, which can create bootable USB installers or export ISO/DMG images from the same app. ISO Image Creator remains available and supported for existing workflows.
Any installer, any format
ISO Image Creator takes an "Install macOS" or "Install Mac OS X" installer app and converts it into a standard bootable ISO, ready to burn, mount in a VM, or hand off to tools like VMware, Parallels, or VirtualBox that don't understand Apple's own installer format.
It supports installers from Mavericks through the latest macOS release, though it doesn't work with InstallAssistant.pkg files or beta versions of macOS.
Mavericks→Latest
Wide installer support
ISO Output
Standard, VM & burn-ready
Full Installers
No InstallAssistant.pkg support
Merged
Now built into Bootabler too
DMGs to ISOs, no friction
ISO Image Creator turns any macOS installer app into a bootable, VM-ready ISO.
Full Installer Conversion
Turn any "Install macOS" or "Install Mac OS X" app into a standard ISO.
Broad OS Support
Works with installers from Mavericks through the latest macOS release.
VM & Burn Ready
Output ISOs mount cleanly in VMware, Parallels, and VirtualBox, or burn straight to disc.
Desktop Output
Grants access only to your desktop, where the finished ISO file appears.
Progress Notifications
A completion notification lets you know exactly when the ISO is ready.
Bootabler Integration
The same ISO/DMG export is now built into Bootabler for a unified workflow.
How to use ISO Image Creator
  1. Open ISO Image Creator and click Agree and Continue.
  2. Click Select the Installer and choose the macOS or Mac OS X installer app you want to convert (InstallAssistant.pkg files and beta installers aren't supported).
  3. Grant the app access to your desktop — that's where the finished ISO file is created.
  4. Click Continue and enter your administrator password to start the conversion.
  5. Wait for the completion notification, then find your new ISO file on the Desktop.
Installer
Full "Install macOS" app (Mavericks+)
Universal (Intel + Apple Silicon)
Administrator password required
ISO Image Creator
DMGs to ISOs,
in a few clicks.
Convert any macOS installer into a bootable, VM-ready ISO image.
What is the difference between a DMG and an ISO?
DMG is a macOS-specific disk image format, while ISO is a universal format recognized by Windows, Linux, and virtual machines.
Can I use these ISOs in virtualization software?
Yes, the ISOs generated by ISO Image Creator are fully compatible with virtualization tools like VMware, VirtualBox, and Parallels.
