ESP Mounter icon
EFI & System Access Utility
ESP Mounter
Instantly mount and browse your EFI System Partition — no Terminal, no diskutil commands.
Download Free
ESP Mounter screenshot ESP Mounter screenshot
EFI access, without the Terminal
ESP Mounter finds every EFI System Partition on your connected disks — internal, external, removable, and even inside disk images — and mounts them in Finder with one click, so you can edit boot configs or check bootloader files without typing a single diskutil command.
It automatically detects OpenCore and Clover installations, flags your active boot disk, and can clone an EFI folder from one disk to another with an automatic backup.
OpenCore + Clover
Bootloader auto-detection
Internal + External
All disk types supported
Universal
Intel & Apple Silicon
Auto-Backup
Before overwriting EFI folders
EFI management, made effortless
ESP Mounter handles detection, mounting, and backups so you never have to touch Terminal.
Instant EFI Access
One-click access to every EFI partition on your system — internal drives, external storage, removable media, or disk images.
Bootloader Detection
Automatically identifies OpenCore and Clover installations, shows version info, and flags your active boot disk.
Menu Bar or Window Mode
Switch between a lightweight menu bar view and a full window interface instantly, without restarting.
EFI Folder Cloning
Copy an EFI folder from one disk to another with a single click, with automatic backup of anything it overwrites.
Filesystem Detection
Identifies what's on each disk before you touch it — APFS and HFS+ for macOS, NTFS for Windows, and ext4/XFS/Btrfs/ZFS and other filesystems for Linux.
Safe by Design
Administrator password stored securely in macOS Keychain, with visual warnings before touching boot-critical disks.
How to use ESP Mounter
  1. Launch ESP Mounter — it automatically scans internal, external, and removable disks for EFI partitions.
  2. Select the disk containing the EFI partition you want to access; your active boot disk and any detected OpenCore/Clover bootloader are flagged automatically.
  3. Click Mount (or double-click the partition) to mount it and open it in Finder.
  4. Edit, copy, or back up EFI files directly in Finder — use the built-in copy tool to clone an EFI folder to another disk, with an automatic backup of anything it overwrites.
  5. When you're finished, unmount the partition from ESP Mounter before removing the drive.
Big Sur 11.0 or later
Universal (Intel + Apple Silicon)
Admin for mount/unmount
ESP Mounter
EFI access without
the Terminal.
Mount, browse, and back up EFI partitions in one click — no diskutil commands required.
Why do I need to mount the EFI partition?
The EFI System Partition (ESP) is hidden by default. Mounting it is necessary to update bootloaders like OpenCore or modify kexts without using complex Terminal commands.
Is ESP Mounter safe to use?
Yes, ESP Mounter safely mounts the partition. However, you should only modify EFI files if you know what you are doing, as deleting critical files can prevent your Mac from booting.
