Mac Tweaks (Legacy) icon
Performance & Maintenance Utility
Mac Tweaks (Legacy)
Legacy version of Mac Tweaks.
Download Free
Mac Tweaks (Legacy) screenshot 1 Mac Tweaks (Legacy) screenshot 1
About Mac Tweaks (Legacy)
Legacy version of Mac Tweaks. Edit this description, the highlights, and every section below from Pages in the admin panel.
Fast
Gets out of your way
Simple
No configuration needed
Native
Built for macOS
No account required
Why Mac Tweaks (Legacy)
A few reasons to give it a try.
Fast
Built to be quick and get out of your way.
Simple
No configuration, no learning curve.
No account, no subscription, no catch.
How to use Mac Tweaks (Legacy)
  1. Download Mac Tweaks (Legacy) using the button above.
  2. Open the downloaded file and move it to your Applications folder.
  3. Launch Mac Tweaks (Legacy) and follow the on-screen instructions.
Big Sur 11.0 or later
Universal (Intel + Apple Silicon)
None required
Mac Tweaks (Legacy)
Ready to try Mac Tweaks (Legacy)?
Do I need to disable SIP to use Mac Tweaks?
Most standard tweaks do not require disabling System Integrity Protection (SIP), but some advanced system behaviors may require it.
Are the changes permanent?
No, any tweak applied through Mac Tweaks can be easily reverted to its default macOS behavior using the same panel.
